Thread: Storing muric acid?
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    Storing muric acid?
    I cover my chlorine in the basement with a black garbage bag over it to reduce it from aging. Do you have to do something similar to muric acid, ie., keep it in a dark place?
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    Feb 2008
    Denton, TX
    5,061
    Re: Storing muric acid?
    I keep my muriatic acid in one of those big Rubbermaid pool storage boxes on the back porch. It's lockable and works great. I also keep my bleach in there as well. Cold could be a problem for you though so I wouldn't want things to risk freezing.
    Muriatic acid is far less sensitive to temperature than bleach is.
    Once concern when storing bleach and acid is to be sure they will never mix. Arrange things so that even if both bottles burst for no reason, bleach and acid still won't come into contact with each other.
    Aug 2009
    North Central Texas
    1,358
    I'm cleaning out two big bin storage containers that have been outside, near the pool, shaded by a big tree for several years, basically undisturbed. It gets sizzling hot here and this winter we had several hard freezes. With the big freeze we had at least an inch of ice on the pool. We usually have at least one hard freeze every winter; down in teens. This is HD MA 3x %.
    When I got down to the bottom of bins I found several bottles of muriatic acid left over from an acid wash in 2004.
    Just out of curiosity I used about 1/2 of a bottle to pour on the steps of pool, let it sit for a few minutes and then swish off, to see if it would do anything to the scale. (pH was 7.8 and I wanted to lower it to 7.2 anyway.) I thought, it's got to be so deteriorated it can't make much difference. Well.............. next day my pH was way down below 7.
    I think keeping it out of the sun and somewhat cool helps a lot. Mind you I'm not advocating storing it that long in extreme conditions.
    I normally keep MA in a big metal shed (metal container like used on ships) that is totally dark but no heating or cooling other than being in constant shade. I've been using the MA that has been stored in there, left over from 2008 acid wash. According to the testing results, when I use it, it hasn't deteriorated much at all.
    BTW..... I keep the MA stored totally away from other pool chems.
    In the second bin I found a bucket of Soda Ash (for raising pH) that has to have been in there for at least 6 years. I used that to raise the pH after I dumped the the old MA in the pool yielding a pretty drastic drop in pH. Worked just as it should have. It was sealed very well so was still in the powder form without any clumps.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
