Thread: What is this white stuff
    Dec 2007
    Switzerland, Fl
    24
    I use an SWG if that makes a difference
    Viking Cancun 16X35, Pentair Clean and Clear Cartridge Filter, Pentair 1.5hp whisper flow,
    SWG
    South Central NJ
    3,192
    Re: What is this white stuff
    If it washes off easily, its salt. If it is still there when wet, it's calcium that deposited itself due to an extended period of unchecked pH rise. Cells produce chlorine but the way it forms tends to raise the pH. This needs to be compensated for. See the Pool School link at the top right.
    Here is a link that describes what needs to happen.
    pool-school/calcium_scaling
    Scott
    Owner of - PoolGuyNJ LLC
    Dec 2007
    Switzerland, Fl
    24
    Quote Originally Posted by PoolGuyNJ
    Scott
    When wet is seems to dis appear
    SWG
    South Central NJ
    3,192
    If you wipe with your hand, is there powdery residue?
    Scott
    Guest
    Is your salt cell plumbed ahead of or behind the spa bypass?
