Results 1 to 10 of 10
Thread: swg intex for in-ground pool
    Is it possible to hook-up an intex swg to my in-ground pool. we are low on funds and need to do something. If I plumbed it in to my existing system how would it know,wouldn't it still work?
    Hayward 1 1/2 HP Max FLO Pump, Hayward Star Clear cartridge filter, Compupool 24 SWG for 26,000 Gal. Pool, 14x28 3.5 to 6 foot painted in-ground Pool.
    Re: swg intex for in-ground pool
    Welcome to TFP!
    Yes this can be done. The Intex unit doesn't care where the water comes from. The main, fairly large, disadvantage is that the Intex SWG is not UL listed, so it is a code violation in most places to use it in this way. Also, keep in mind that the Intex instructions say to make sure the SWG is turned off any time someone is in the pool.
    so could i run the pump on off hours like at night?
    would it be harmful if it was on while you were into it.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by davids1973
    There is a risk of electrical shock.
    even if it's on a gfi?
    Butterfly's Avatar
    South Carolina
    10,045
    There is a lot of info on the unit here: Intex SWG
    You can also do a search for intex (bottom left, google). We have lots of members with this SWG and they will be chiming in.
    You're done SLAMing when:
    what about the swg intex in conjunction with an ionizer
    The ionizer does not have any effect on the SWG either way. On the other hand, we generally recommend not using ionizers.
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    The unit is marketed specifically for temporary(non-permanent) pools. IMHO don't think that there would be any point in UL listing, nor would it be a code violation if it were not permanently installed (ie, you don't hard wire it.) It is always a good legal point to recommend that ANY electrical device connected to a pool be de-energized when someone is in the pool. The lawyers at the other pool equipment suppliers are just lagging behind, or not as paranoid!
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
