Results 1 to 8 of 8
Thread: Pool liner floating after flood
    Jul 2015
    mulvane, ks
    5
    Ive read and been told that i need to find the vacume pipe but nothing sticks out
    20x40 in ground pool
    30,403
    Re: Pool liner floating after flood
    Welcome to the forum.
    That's not much info but I assume someone is trying to direct you to a sump point (wellpoint) whereby you can extract water from behind the liner. It usually doesn't "stick out" but it rather is covered like a skimmer. You may not have any, also.
    Jul 2015
    mulvane, ks
    5
    There is an extra plug in the skimmer basket, is that it?
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,372
    Look for a pipe stub in deep end or near equipment pad...
    Chances are liner will sink soon & you will be left with the classic "spider web" shallow end wrinkle...
    To combat floating in the future - sandbag the 4 shallow end corners & middle. At least when it floats it will sit relatively close to normal...
    Unfortunately "once a floater always a floater"
    Jul 2015
    mulvane, ks
    5
    There isn't anything anywhere except for in the skimmer basket
    Jul 2015
    mulvane, ks
    5
    Is there any way to get the wrinkles out
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    some have used a plunger with success.
    Dolphin E10 Cleaning Robot.
    Jul 2015
    mulvane, ks
    5
    And just pull it to the side
