Thread: Plaster question
    May 2009
    So Cal
    44
    Plaster question
    Hello all,
    I have a question about plaster, my pool is about 8 months old and the dark grey plaster is getting a lot of small cracks, is this normal or should I be notifying my PB?
    15 X 28, 12,000 Gallon, (IG) Freeform Dark Gray Plaster/Gunite with attached 10 X 7 Spa raised 18", 7 Jet with Spillover and Art Rock Waterfall/Grotto, Pentair Intelliflo VS-3050 for Pool, 2 HP Whisperflo for Waterfall/Grotto, Pentair Clean & Clear Cartridge 320, Pentair 400K BTU Matstertemp, Pentair EasyTouch 4P, Pentair Suction Side PoolShark Cleaner, Stenner pump, autofill system, Plumbed for future Solar, TF-Testkit.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Plaster question
    Yes, it is pretty typical to get tiny hairline cracks in the paster especially if it was installed when it was fairly hot. Called crazing in the industry, it shouldn't be an issue as long as they have no real depth and are only cosmetic.
    Mark
    May 2009
    So Cal
    44
    Thanks Mark, I was starting to get concerned.
