Results 1 to 10 of 10
Thread: gap in the coping
    Aug 2016
    chandler az
    11
    gap in the coping
    is there a good silicone that I can use to seal about 1/2" gap between the pool and coping?
    chlorine pool
    15,500 gallons
    in-ground
    Pentair cartridge filter
    1 hp motor
    May 2012
    Montville NJ
    545
    Re: gap in the coping
    Quote Originally Posted by louman007 View Post
    Where exactly is this gap? There is no gap between the pool and coping that is supposed to be there, that needs to be sealed.
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Aug 2016
    chandler az
    11
    right above the pool tile.
    there are crickets that get in there and when we jump in the pool and water gets in, they jump out.
    chlorine pool
    15,500 gallons
    in-ground
    1 hp motor
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Polyurethane caulk is better.
    Pepo's Avatar
    Mar 2015
    Orlando, Florida
    12
    You can use marine sealant 3M 5200 that stuff is the best, seals really well and is waterproof.
    15k Gal. ig Pool & Spa quartz plaster, Hayward super pump II 2.5 HP, Hayward 425 sf. cartridge filter,
    PS-4 Goldline automation, SWG(not working) using liquid chlorine now, Hayward 250k BTU propane spa heater.
    DFW, TX
    24,483
    Yes, that is a good polyurethane caulk.
    Aug 2016
    chandler az
    11
    thank you
    chlorine pool
    15,500 gallons
    in-ground
    1 hp motor
    Jun 2016
    Peoria AZ
    57
    Good deal, Was just looking at this myself as I need to do the same thing
    10k gal, IG Plaster, 3/4HP WhisperFlo pump, A.0 Smith Centurion single speed motor, Pentair TritonII sand filter, TF100 test kit, Hayward suction cleaner, City well water
    May 2012
    Montville NJ
    545
    Maybe its me. Your sig says you have an above ground pool, but you have a tile wall ?
    -dave
    Zodiac Wahoo
    Aug 2016
    chandler az
    11
    typo on my end. it is an inground pool. ill correct. thank you.
    chlorine pool
    15,500 gallons
    in-ground
    1 hp motor
