Thread: FC generation versus pump speed
    Apr 2016
    Tuscaloosa, AL
    12
    If run time and SWG % are equal, do higher pump speeds generate more FC than lower speeds?
    Sorry if this is answered else where.
    Rick
    18X39X32 T-Shaped vinyl liner IG pool, deep end is 8ft....Metal walls... Hayward Ecostar, AQL-Plus Salt, 30" sand filter...completed July 1, 2016!!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: FC generation versus pump speed
    Nope. SWG is on the same no matter the pump speed.
    Dec 2014
    Santa Ana, CA
    523
    Quote Originally Posted by RPSwat View Post
    Rick
    I don't think so- it would generate less concentrated chlorine at higher speeds but the same amount determined by your cell electrodes area.
    44k plaster pool, Pentair 011018 pump, DE6020 filter, LED lights, K2006 test kit
    Apr 2016
    Tuscaloosa, AL
    12
    Great-thanks!
    AUSpool's Avatar
    Sep 2015
    Sunshine Coast, Australia.
    358
    I had recently been thinking about the affect of pump speed on the SWG cell. The same amount of hypochlorite acid is produced according to the chlorinator setting regardless of pump speed but is there any difference in the super chlorination effect of the cell with a change in flow rate and dwell time. I recently decided to test my return water for pH and FC, my pool had a FC of 8ppm and a pH of 7.8 and the return water had a FC of 10ppm and pH of 7.8.
    Steve.
    30,000L (8,000g) Pebblecrete | Davey 3sp Eco pump | Poolrite sand filter & SWCG |
    Waterco solar panels & Astral E140 pump| K2006, BlueDevil pH, Salt meter & K1766 | Town water - pH 7.2, TA 50, CH 60 | Esky full of coldies |
