Thread: Pump runs fine on recirculate but not on filter setting
    Aug 2016
    Danvers, Ma.
    1
    Hi there, did you resolve this issue? I'm having same problem but in ground pool.
    Mod edit: New thread
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pump runs fine on recirculate but not on filter setting
    Do you have any more detail about your pump and filter set up? Filling out your forum signature with details about your pool will help us help you. That way we can see your equipment and pool details in each post. Update your signature here: Edit Signature
    Did you change anything recently with the filter or pump?
    Isolated Spa - 345 Gallons
