Page 1 of 7 1234 ... LastLast
Results 1 to 20 of 138
Thread: Just had new pool start up
    May 2015
    Fullerton, CA
    594
    Did not help much
    Pool calcium is at 170
    FC= 0.2
    PH= 7.8
    He added 1/2 gallon of acid and said adding chlorine would be a waste as there is no CYA in the pool??
    Help?
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Just had new pool start up
    More information is needed, please go to pool school and read all, several times, how are you testing your water and how it looks... The relationship between bleach and CYA is the corner stone of TFP look at the link in my signature, it have to be maintained all the time
    Starting day 5/25/2015 INTEX AGP 24'x12'x54" 8,400 gal, with salt and borax, INTEX 3,000 GPH pump with 16"sand filter, WM Hayward Skimmer, Intex SWG CG-28669, 1 1/2" hard plumbed PVC, Lil' Shark Vacuum With Leaf Canister, TF100 test kit, speed stir, K-1766 Taylor salt test
    Pool School - Chlorine / CYA Chart
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Mod Squad pooldv's Avatar
    DFW, TX
    18,295
    That is true, with no CYA the sun will burn off the FC very quickly. You need CYA and Chlorine.
    Here is some good info
    ABCs of Pool Water Chemistry
    Pool School - Getting Started
    Who is doing the first 30 days? The first 30 days is critical to plaster success. Did PB give you a start up guide? Did you check the plaster mfg online for their start up guide? Most also have online warranty registration.
    May 2015
    Fullerton, CA
    594
    Okay, so should i not add chlorine until i can pick up some CYA tomorrow? What is the cya in the sock method?
    I cant believe they just left me hanging, i would have picked up the stuff i needed today.
    So i am brushing twice per day. The pump is on a 12 hour schedule. Do i test again tomorrow night?
    Add cya and chlorine or just cya or just chlorine?
    Sorry to panic but i expected more from pool training
    DFW, TX
    18,295
    More here from your plaster mfg on how to start up
    FAQ | National Pool Tile Group
    Overview | National Pool Tile Group
    May 2015
    Fullerton, CA
    594
    Thanks. Well since i had neither a traditional start up or an acid start up is there a preferred method?
    I have read the pool school stuff but at this point acid method was not done so i guess traditional?
    I will test everything in the morning but it appears i cant add chlorine for 48 hours after fill, so cya first then chlorine, cant find the sequence anywhere?
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    2,566
    Here's a good article on recommended chemicals and how to add them.
    Yes, start the CYA and then maintain the rest per the plaster start-up guide. The sock method for CYA means putting the CYA powder in an old sock with no holes in it. Tie it at the top with string and use the string to hang the whole thing in the pool, in front of a return jet. Use a stick or board to hold the hanging sock away from the side of the pool. Squeeze the sock every now and then to help the CYA dissolve. Rinse your hands after.
    Get familiar with PoolMath. And if you haven't already, order this test kit: TFTestkits.net
    Get it delivered quickly if at all possible. If you already have it, post your test results and let us know any questions or concerns you might have.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | FC / CYA Chart | Read Before Posting | ... and this helped me a lot!: TFPC for Beginners
    DFW, TX
    18,295
    When a sequence is not specified it is because it is not important. You are correct that it is now by default a traditional start up.
    +1 to learning how to use PoolMath and don't guess how much to add. There is a link at the top of every page and there are directions at the top of the PoolMath page.
    May 2015
    Fullerton, CA
    594
    Test results this morning
    Tc=.5
    Tb-1
    Ph-7.5
    Ta-110
    Ch-325
    On the ch test, do i stop drops of r-0012 at the first sign of light red or add more until darker red? That was the difference between 11 and 13 drops?
    I am using a tl-100 kit
    So based on the numbers i am in the zone except for chlrine.
    DFW, TX
    18,295
    Please stop asking the same questions in two different threads. I just answered your CH question in your other thread.
    May 2015
    Fullerton, CA
    594
    Sorry, will keep chem talk here.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Keep adding drops until no further changes, subtract the last drop
    May 2015
    Fullerton, CA
    594
    Quote Originally Posted by Piolin View Post
    Thanks, I was not mixing after each drop, until I saw the expanded directions, will need to redo. Strange, the pool guy had this digital "safe dip" that said my CH was 170 yesterday, perhaps I screwed up the test?
    I did pick up some conditioner (CYA) at a pool store, they told me to pull the basket out of the pump, put the lid back on and then start the pump and pour the CYA (granules) into the skimmer basket?
    I am going to do this tomorrow afternoon, as traditional start up says no chlorine for 72 hours, NPT says no chlorine for 48 hours. I figure tormorrow afternoon I will just do it.
    DFW, TX
    18,295
    I would do 48 hours. Don't wait too long or algae will start growing and you don't want to have SLAM a pool in the first 30 days. No, do not put the CYA in the skimmer. More here on how to add chems to your pool, Pool School - Recommended Pool Chemicals
    May 2016
    Phoenix AZ
    128
    I would follow the advice you get here, not at the pool store.
    So, if you are told here to put the CYA in a sock in front of a return, and at the pool store to add it to the skimmer, put it in a sock in front of a return.
    50,000 gallon plaster in-ground salt pool with two 60 sq ft DE filters, two Intellichlor IC60 SWGs, two Intelliflo VS pumps, two Whisperflo pumps, two Pentair 400K BTU NG heaters, PCC2000 in-floor cleaning system...two everything.
    May 2015
    Fullerton, CA
    594
    Ok, 48 hours post fill is 10pm tonight. Does it need to be exactly 48 hours, its dark at 10 pm or can i add chlorine and cya say 8pm or friday am. I know i sound paranoid but i dont know how exact i have to be.
    Thx
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Have you look at the speed stir?
    TFTestkits.net
    DFW, TX
    18,295
    No, it does not. 7 or 8 is fine. And test again an hour later to see if it held and add more if needed. And again an hour later. Just in case there is something in the water consuming chlorine.
    needsajet's Avatar
    Jan 2016
    2,566
    Don't feel anything other than normal. We've all been there, lol. You'll be comfortable with it all in no time. Do the suggested reading; the linked articles are quite short.
    Whoever told you to run your pump without its strainer basket is either a numbskull or is hoping to sell you a pump someday.
    What's great about this site, and keeps it great, is that if anyone says something wrong or misleading, an expert will jump in and correct it.
    All good, you're learning fast
  20. Back To Top    #20
    DFW, TX
    18,295
    Quote Originally Posted by needsajet View Post
    LOL! Right!
