Results 1 to 11 of 11
Thread: Intex Filter problem - combating algae
    I have similar problem. While treating brown algea my cartridge clogs really quick. Could I run the pump without it? Oh, agp 6300 gal. oval, intex pump model FP621.
    Thanks
    jolane
    Jolane
    AGP 6300 gal. oval, intex pump model FP621.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Intex Filter problem - combating algae
    Hi Jolane, welcome to TFP!
    You can put your specs in your signature line - go to User Control Panel, then Profile, then Edit signature. Put all your pool/equipment info there, then you won't have to repeat it, and we won't have to search for it.
    No. The filter is what clears the water of the dead algae. Intex are notorious for being inadequate filters once a problem like algae develops. With the filters, which are disposable, they should be tossed with normal use every 2 weeks. With algae, I suspect they won't last a week, and you need to hose them off frequently because of the clogging you describe.
    If you could post a full set of water test results, we may help you better.
    (Many Intex users figure out a way to vacume to waste. Once the algae is all dead, they shut the pump off, the gunk settles to the bottom, and they vacume to the yard, bypassing the filter. It does waste a lot of water this way, but often it's the only solution short of draining and refilling to start over.)
    Are you certain your algae is dead?
    If you haven't read Pool School, that's a great place to start. I also would advise you to invest in a good test kit. If you prevent algae in the firstplace thru proper testing and water maintenance, then the filters shouldn't be as much of an issue.
    Hope this helps.
    Welcome to TFP!
    I believe the Intex filters will work without a cartridge. However, you are going to need to filter the algae out at some point, so you might as well work on it now.
    West Michigan
    108
    If you have an Intex pool you will want to use some Mule Team Borax in it. It will go a long way in keeping your little pool sparkeling. I buy several of the filters and spray them of every few days with a hose. Its a pain to really clean the yuck out of all those pleats but it will make them last longer. Using a pantyhose in your skimmer will help you use them more effeciently too. The biggest problem with the little pools besides the inadquet filter is too much cya from using the pucks... Kimrst
    5 years 18' Intex Frame pool, July 2009 upgrade, 28ft rnd used Doughboy, 1hs Hayward Power Flow pump, Doughboy DE filter.TF test kit
    Thanks for all the tips. Still working on this.
    Test Results
    FC=15-20
    TC=10.2
    CC-5
    PH=7.5
    CH=270
    CYA=30
    TA=180
    This DPT test kit is all new to me. The chlorine test does not go high enough so thats a guesstimate.
    Been filtering for the past few days. Figured out the pump problem. It was crystalization in the skimmer from last yr. I have soaked and sprayed the filters till I m blue in the face. Oh well. The good thing is I can finally see the bottom, as long as I don't stir it up. OH by the way I have read most of the posts and pool school since last yr.. It really helped out especially The BBB. I use pure bleach now.
    Anyway, what can I do now?
    Jolane
    11,969
    Continue to shock your pool until:
    Your FC holds overnight or you lose less than 1ppm;
    your CC is .5 or less;
    your water is clear.
    Also, order an FAS-DPD test, for about $25 - from either TFtestkits.net or Taylor's website. You need to be able to test FC higher than 10 and your testkit won't do that.
    Nick's Avatar
    Jun 2008
    Bristol, UK
    36
    Personally I gave up on the Intex filters.
    I have both a 1500 gph and a 500 gph unit. For filtering performance they are both about as much use as a chocolate tea pot.
    I decided to use the 1500 gph unit simply as a fast pump and use a bio diesel filter bag to filter everything including algae. It works a treat. A few days ago we went from Green to clean in about four hours.
    ps. I took the filter cartridge out.
    Intex 16'x48" AGP 5,000 (uk) gallons
    Intex 635 pump
    Bio Diesel filter bags
    4 solar radiators and a solar cover
    West Michigan
    108
    Nick, What is a "bio diesel filter bag" ? You took the paper filter out and put that in its place? How long did you run it per day? Kimrst
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    Quote Originally Posted by frustratedpoolmom
    Hope this helps.
    Poolmom...I suspect that with algae clogging filter, you would be lucky to get more than a day or two out of the disposable cartridges I would suggest getting 4 or 5 and rotating them out once a day...cleaning and then reusing for another day...I would not use them more than two or three times when filtering a pool with algae...they just ren't made for that. You also could try soaking them in bleach after cleaning...for added little kick...This is what i used to do with my pool when I had and intex...
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Feb 2008
    Northwest Indiana
    900
    http://www.filterbag.com/size.html
    Biodiesel filter bags...Check it out...Could be useful for pools!!!
    Beave
    Nick's Avatar
    Jun 2008
    Bristol, UK
    36
    Quote Originally Posted by cubbybeave08
    Sorry for the late reply.
    That's the sort of thing, although we got ones on Ebay, 30 inches long for a lot cheaper.
    They have done a great job in filtering the pool all summer.
    Intex 635 pump
