Hey everybody. New guy here. Sorry for the long post but I’m at a loss. I’ve read several threads similar to this but never figured out what this grey powder could be if it’s not algae. I’ve fought this on and off, mostly on, for 5 or so years. This grey powder shows up on the bottom of my pool and after I vacuum on waste it always comes back, usually by the next day.
About 3 years ago I decided it was mustard algae, started reading this forum and determined my CYA was too high, around 110-120, and likely the problem. I was brushing the pool after dark every night and keeping the chlorine super high with bleach all while gradually lowering the CYA by draining water and it still kept coming back. Eventually after getting the CYA down around 70 my wife tired of the whole process and started using something called algae complete, which I know you guys don’t recommend, but it seemed to work. Everything has been fine the last couple years until this year it’s come back again even with the algae complete. Based on a faulty reading at a pool store I ADDED CYA because it was supposedly low. So it wound up back in the 110-120 range again. I’ve gradually gotten it down to about 80 as of today.
I’m still not 100% convinced it’s algae though. It’s only on the bottom of the pool, not the sides and doesn’t really “cling” to anything but it does disappear into a cloud of dust if you brush it and eventually resettles. Also the water is perfectly clear. Several months ago we had vacuumed it to waste and with a few hours there were some small spots right around the edges where the jets blow. So I turned off the pump and let it sit for a few days. Nothing else showed up. Two days later I turned the pump back on and it began to accumulate again. So this sounds more like a filtration issue or something being pumped in, right?
I finally got so frustrated that I called a pool company and the owner immediately said it was dead algae. We figured it was not being filtered out effectively so we changed the sand in the filter, which I also know is not recommended but I figured it wasn’t gonna hurt and would at least take that out of the equation. They also verified none of the laterals were broken. Well after several months of very questionably maintaining the pool and not getting rid of the problem the owner has come back out and decided it’s NOT algae. He’s determined it’s some type of chemical fall out and speculating calcium. It’s a vinyl liner pool btw around 17,500 gallons. I just checked my reading today with the TFP test kit and got:
FC 11
CC .5
CH 125
CYA 80-90
TA 50
PH 7.5
So it doesn’t sound like it would be calcium. Oddly even when we’ve managed to get rid of the stuff every time we add balance pak 100/baking soda it seems like it comes back.
Was hoping someone here could tell me if this sounds like definitely algae or could it be something else, and if so, what?
Thanks
FC 11
CC .5
CH 125
CYA 80-90
TA 50
PH 7.5
Thanks
