Thread: Do you use a floculant?
    Fayetteville, Arkansas
    220
    At start up each season - does your pool water require a clarifier/floc treatment to attain sparkling water? I have a mesh cover, so you know what I face each year.
    Just wondering?
    20x40 30,000 gal IG Liner, Pentair II Sand
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Do you use a floculant?
    No. When I open mine, any debris that came through the mesh is on the bottom. I vacuum the pool, raise the chlorine level and let the filter run continuously until the water clears completely.
    220
    Quote Originally Posted by JohnT
    Do you open very early? You don't have any algae bloom? When I uncover mine, it's the green lagoon, so I add the CYA, add the bleach, and then it begins to clear, but the killed algae turns white and thus the cloudiness of the water. I have used a floc for the last couple of years since that stuff just seems to suspend in the water for a long time without help to settle it to the bottom so I can vac to waste. I do turn the pump off for the floc to work.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Sand filters take longer to clear dead algae, so some people like the floc cause it speeds up the process. Assuming one doesn't mind the added expense. DE in the filter has reported good results.
    Can you open earlier?
    Rangerman, time for you to get a siggy.
    SW Indiana
    9,199
    Quote Originally Posted by Rangerman
    I open when the water hits 60 degrees. No algae, just dirt and worms.
    Jun 2007
    NC
    255
    Do you open very early? You don't have any algae bloom? When I uncover mine it's the green lagoon...I add the CYA, bleach, and it begins to clear. The killed algae turns white and thus the cloudiness of the water...used a floc for the last couple of years since that stuff just seems to suspend in the water for a long time without help to settle it to the bottom so I can vac to waste. I do turn the pump off for the floc to work.
    This year I opened in late March, usually early to mid-March so the water was warm enough to turn slight green. The gunk had gone through the safety cover but could be vac'd off of the bottom. Shocked it, added water and CYA (mine was 0), kept the SWG off, and I had a pool that we were in (well, my teenagers anyway) within 2 weeks.
    Not too bad: No floc, no clarifier, just CYA & bleach 8) .
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
