Thread: Pool timer
    Jul 2016
    Hudson/New Hampshire
    23
    Pool timer
    Hubby got a timer for the filter. He was wondering how many hrs filter should run for, and at what time of day? Thanks
    Jul 2015
    Central Valley CA
    1,109
    Re: Pool timer
    Time of day does not matter unless you are on a time of use rate plan that makes it cheaper to run at night. As for how long depends on the pool, start with 4 hours and see how the water looks if you like it you are good to go if it looks a bit cloudy increase in 30min to an hour increments every couple of day till it looks good to you. Take a look at THIS
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jul 2016
    23
    Re: Pool timer
    Thank you! We are so lost
