Thread: Liner install
    May 2016
    Midwest USA
    11
    Liner install
    Help!! Does this look right?? Most is very relaxed but this side is so tight. Is this bad??
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Re: Liner install
    I think it needs to be adjusted. See this thread and its pics: Sharkline Matrix 24'x54 DIY install.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Re: Liner install
    It does need to be adjusted. There is too much of the floor pulled over to the other side causing the side in the pic to be too tight or have too much tension.
    You'll want it somewhat equally taught all around but not THAT extreme. It will stretch into place but the way it is now you are risking buckling the wall as it fills and pulls on the liner.
    It's better on the liner to stretch equally as well as on the walls so they don't buckle.
    Also if you have a shop vac you can cover up the skimmer and return openings and use the vacuum to suck most of the air out and it will help seat the liner as you start filling it.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
