Thread: tf-100 complete refill set?
    May 2009
    Jasper, TN
    I see you can buy a complete refill set for the tf-100 kit.
    If I don't need a fancy box and have tubes from another kit, can I just use the refills as long as the water measurements are the same?
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    Jan 2009
    Cupertino, CA
    Re: tf-100 complete refill set?
    Sure. As long as you can measure 10ml and 25ml samples, and have a CYA view tube, you can just buy the refills.
    BBB "Intermediate Swimmer"
