Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 87
Thread: Post what your pool cost you to build...
    spoonman's Avatar
    Jun 2016
    Peoria, AZ
    241
    Please share what the cost was to build your pool, the size of your pool, and if it is in-ground or above ground.
    spoonman's Avatar
    Jun 2016
    Peoria, AZ
    241
    Re: Post what your pool cost you to build...
    I'm working on a 13x26 in ground pool. Cost is about $29k
    Sep 2015
    Tucson, Arizona
    86
    Working on a 16x32 in-ground pool + 6x8 spa + rock grotto/waterfall.
    Cost will be about $44k.
    Owner Build. 32x16, with 6x8 raised spa. Broke ground April 1, 2016, swimming July 18. Pentair Intelliflo VS + Whisperflo for Water features; Clean & Clear Filter 420; Master Temp Heater 400k BTU; Intellibrite 120V pool and spa lights; Regular ol' plaster.
    Aug 2009
    SW Wisconsin
    518
    33 foot Diameter round above ground pool, bought used (2 years old) = $600
    contractor to level/prep ground = $600
    25,000 gallons of water delivered = $800
    New Liner = $400
    Gas line run for heater = $250
    TOTAL = $2650.00
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Jun 2016
    Central Valley, CA
    31
    16x32 in ground gunite/plaster with 1000sq ft decking $34,800.
    Pretty standard pool, Hayward 1.5HP VS Pump, Pentair 60 sq ft DE filter, dual low voltage LED lights, 5 deck spitters, and a fair amount glass tile at the water line and trimming the steps and benches.
    We had 3 bids low was 32,300 & high was 38,100.
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    Broke ground a month ago on a 18 x 38 gunite with pebble finish. Fiberglass hill slide and tanning ledge with LED bubblers. $46k...... $46700 if I add the SR Smith basketball hoop
    18 x 38 gunite, 39-7 deep, 8 x 12 tanning ledge with 8 deep water, umbrella sleeve, 2 LED bubblers.
    2 Pentair LED lights, 16 long fiberglass hill slide and jump rock. Sand dune pavers/coping. TF-100. My build: Georgia Pool Build.... No Longer O/B :))
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Pool/spa 39'x14' gunite with pebble plaster. $60,000 in Texas. Include location when posting.
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    texasgal78's Avatar
    Feb 2016
    Prosper, TX
    87
    Wow...how the heck are y'alls prices so low?? We did an owner build in ground gunite 36x20. We haven't gotten our finally tally, but will probably be around $55k+. We are in the Dallas area.
    My 2016 pool build Owner build 104' free form IG sport pool,20'x36' (18,300 gal)~7'x8' raised spa with spillover~Oklahoma flagstone coping~12" raised beam with dry stack wallC~Cascading waterfall grotto with flat moss rock~630 sqft salted concrete deck~Deep blue sea-prism matrix~2 Hp Jandy epump~1.5 Jandy stealth~CL580 cartridge filter~Jandy jxi heater~iaqua link 2.0 ~dolphin m500 robot~LED pool lights (2 pool, 1 spa)~TF-100 test kit
    Aug 2015
    Cypress
    1,679
    Quote Originally Posted by texasgal78 View Post
    Sent from my SM-G930T using Tapatalk
    I feel you! Ours was in that range and up too here near Houston!
    May 2016
    fort worth, tx
    123
    I'm glad you said that. I was feeling like a chump!
    Construction began 5/2016. IGF pool. 41' x 21'. Jandy DEV60, Jandy 2hp 2sp pump, Polaris 280 Black Max, Rainbow 320 chlorinator, Jandy JXI 400, Jandy iAqualink, Jandy LED's. 2'x2'x10' rock weeping wall. Dive rock. Tile/Plaster: NPT Silverstone AquaMarine Decking: Stained Stamped Concrete/Stonescapes Aqua Blue with glass beads and abalone. http://www.troublefreepool.com/threa...-Fort-Worth-TX
    Mar 2013
    New Hampshire
    351
    My size is below and our price was about 45k with the decking....
    18k: IG: Black Granite Liner: Aspen: 16x33.5: SWG: Polaris 280
    My pool build new-pool-build-in-nh-t60957.html
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    I find these threads to be fairly unhelpful other than to satisfy curiosity and get some sense of a ballpark price for an area and pool type. There are dozens of factors influencing pool prices in a given area at a given time. Including the customer and bid request. The only price that is meaningful is the one given to you by a builder for your specs in your yard. It could cost more or less to build the same pool at the same time in your neighbor's yard as it does to build it in your yard. We trimmed over 13k off the price of our pool by changing just a few things and got essentially the same pool. Having clear, open communication with a PB you trust is the best way to get the most pool for your money. And be very wary of the lowest bid. Telling your PB that Joe and Rita in Peoria, MS got the same pool built for 29k will probably just get you a 5k price increase.
    texasgal78's Avatar
    Feb 2016
    Prosper, TX
    87
    Quote Originally Posted by twinkiesmommy2009 View Post
    I guess everything IS bigger in Texas, including price!
    texasgal78's Avatar
    Feb 2016
    Prosper, TX
    87
    Quote Originally Posted by Technobuyer View Post
    Haha!!
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    Approx. $50,000 for pool plus $10,000 for screen cage.
    Had estimates from 8 PBs all BBB rated A+.
    5 were $10,000 or more higher. Narrowed down to 3 lower estimates in the same price range. The one I picked, a small ma & pa PB built 4 pools over 2 yrs. in my community and was recommended.
    But things change and now he's overloaded and I'm not a happy camper.
    My 2016 Build 14'x19'x35' IG Gunite 15K Gal. Roman, 4'-5' deep, 6 returns, 3 sheers
    4 deck jets, 2 Pentair XF22005 Pumps, Clean&Clear 200 Cartridge Filter, Brick Coping
    2 Pentair 5g 12v LED Pool Lights, 1 Pentair 12v Globrite LED in step area, 2 Bubblers
    Inline Chlorinator - SWG later, WetEdge Mediterranean Pebble, Intermatic MultiWave
    43'x33' Screened Paver Deck&15'x30' Lanai, Doheny Discovery (S200) Robot, TF-100
    May 2016
    New Caney, TX
    23
    16x30 Fiberglass pool from Leisure Pools, model is called The Ultimate. Built in spa and splash deck. Hardware wise, it's all Hayward eqpt, SWG, 250k BTU natural gas heater, 4 LED multicolored light, 4 deck jets, Omnilogic automation controller and an additional 400 sq ft of decking with Kool Deck spray for $47,000. This is in New Caney, TX, just Northeast of Houston.
    May 2016
    Dallas/TX
    276
    Dallas,TX.
    Pool (34 x 17, Freeform, 96 Perimeter), Spa (7x7, Freeform), 10' Grotto, 12" Raised Wall connecting Spa to Grotto, Blue Granite Pebblesheen, 488sq ft of Noce Travertine, All Jandy equipment including JXI 400K (w/ 2016 Versaplumb bypass),2HP Variable Speed pump, Aquapure SWCG, and iAquaLink automation, a raised level going from main pool level to spa, 4 LED lights, Polaris 280, Bobcat Shuttle for excavation, 1/2" rebar, #10 centers, etc.
    I will get out the door at $68.9K. Quoted 5 other reputable builders, this was $4-$5k less than everyone else. We splurged a bit and went with a builder that would put in a high quality pool. I could have gotten similiar for $62K-$64k from a high volume builder in the area, but you get what you pay for in my opinion. I don't plan on moving for 7-10 years, but I have seen crappy inground pools so decided building was the right thing to do.
    If anyone is looking for finance tips, I secured a 20 year fixed @ 5.99%. Only financing 40% and plan to have this all paid off in 2 years, but it gives me cash flow options.
    May 2016
    Prosper/TX
    9
    Prosper, TX
    17x28 geometric pool, raised 7x7 spa, 1200 sq ft of paver decking and a 12x12 covered structure, will finish around $65k
    Jun 2016
    Central Valley, CA
    31
    There are so many variables that affect price. In our case we intentional went fairly basic. No automation, no spa, no waterfall, no slide, no grotto, etc. Our last pool included all these things and we rarely used any of them. This time we focused only on the function that we wanted from the pool, we don't care to impress any of the neighbors ��
    A couple other elements that went in our favor...
    1) we had wide open access to the site
    2) we are in a new custom home neighborhood and many home sites need fill dirt so the dump trucks had less than 1/4 mile to dump dirt at no cost.
    3) we are the one of the first houses completed and all the local PB want their signs in the first homes in hopes of landing more jobs.
    We we do have a couple neighbors building showcase pools, similar to what a lot of folks here have or would like build. There are a couple $60k+ builds happening in the neighborhood too. These have huge pools with several thousand feet of decking with fire pits and out door kitchens. They are beautiful but way more cash than we are willing to part with.
  20. Back To Top    #20
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    20x28 vinyl sports pool w/concrete deck, with all the equipment listed below, 165' of fencing with two 4' gates. All electrical work, grade work, stereo system, I came in right at 25k.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
