Thread: Equipment question
    adeprekel's Avatar
    Mar 2016
    Lebanon/TN
    8
    Equipment question
    I need to disassemble this hose to take into the store for a replacement part and i cannot get it to unscrew. Can someone tell me how to unscrew this hose at the joint? I need that larger end on the left replaced. TIA.
    2001 pool built-Remodel date unknown-Size of Pool: 15,200 gallons-Salt Water In-Ground Pool-Vinyl liner-Pentair Triton II Sand Filter-Pentair Intellichlor C20 pool cell-Pentair single speed pool pump (i think)-Polaris PB4-60 pressure cleaner booster- 4 way tester
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Equipment question
    I wish I knew, where you able to get it off? Looks like it should just unscrew...
