Thread: whats the best sand filter for my pool?
    My s-200 high rate sand needs to be replaced. I have a 16 x 32 in ground 18000 gallons. Whats the best one out there? Where should I by it Amazon? Thanks.
    18k IG 16'x32' vinyl liner Haywood S-200 high rate sand filter pump Haywood Encl.3 1hp A.O.Smith Corp
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: whats the best sand filter for my pool?
    is the outer filter bad or is it just the innards? or do you just want a new one
    The pentair TF100 is a beast and should fit good for that size pool, it needs 600 pounds of sand...
    Amazon.com : Pentair Triton II Side Mount Filter TR100 Fiberglass Sand Filter without Valve : Swimming Pool Cartridge Filters : Patio, Lawn Garden
    I hope this helps
    Thanks for your help cowboy.
