Thread: setting up ag and measurements
    May 2016
    Missouri
    13
    Ok we have the side supports all with in an inch of each other and all of the round corners and inch from them and each other is this ok or do they need to be closer
    Kc mo, mom of 3 and a farmers wife
    Looking at a 18x40x52 Above ground pool
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    Re: setting up ag and measurements
    Within an inch is good. Maybe make one more pass to tighten it up one more time and move to the next step.
    May 2016
    Missouri
    13
    Thank you
