Thread: Adding and removing water at same time?
    Jun 2016
    Buffalo, NY
    65
    CYA is up to 120, so I'm going to empty some of the water from my pool.
    I was thinking of pumping water out at the same time i'm filling it.
    Thoughts?
    12,000 gallon AG pool | Hayward 1HP pump | Hayward Perflex DE filter (I hate DE) | Taylor K-2006 Test Kit
    triptyx's Avatar
    Apr 2016
    1,438
    Re: Adding and removing water at same time?
    Unless you segregate the water with a tarp or some other method to avoid it mixing together, you'll be pumping out new water with the old and will not have as much effect on the CYA PPM.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Jun 2016
    Buffalo, NY
    65
    Quote Originally Posted by triptyx View Post
    Thats what I figured.
    I was hoping I was wrong.
    triptyx's Avatar
    Apr 2016
    1,438
    Effectively, you can certainly do it, it's just going to require more water than if you did a drain and then a fill separately.
