Thread: How does it work?
    Oct 2015
    San Diego, Ca.
    650
    How does it work?
    My neighbor has a Barracuda G3 pool vacuum.
    I can't seem to figure out how the thing pulses which, I assume causes it to move around the pool.
    Anyone know the principle of it?
    Thanks
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: How does it work?
    It is the diaphragm that opens and closes which creates the pulsating movement.
    When closed it reduces the flow rate but increases the pressure on the diaphragm which then opens. Once opened, the pressure drops and closes again. This is repeated over and over again.
    Mark
