Thread: aqua plus settings
    Jun 2016
    Port Jefferson Station
    49
    aqua plus settings
    I just got a swg and not sure what to set the pool chlorinator setting at on my panel the default is 50% is this correct thanks
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: aqua plus settings
    Welcome to TFP
    Try starting out at 50% and a pump run time of 8 hours and go from there, testing and adjusting..
    What are you testing the water with, do you have test numbers?
    Check out the links below
