Thread: Draining Pool
    Jun 2016
    Israel
    23
    Draining Pool
    I need to drain the pool. What is the best method to drain the pool once the pool water is below the plug on one side. The other side its still above the plug.
    Draining it because the level is off.
    I have a 12 foot summer metel frame pool.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,457
    Re: Draining Pool
    You can use a submersible pump. Here in the states we can rent them or buy cheap ones ($60 or so) from Harbor Freight.
    Kim
    Mar 2015
    US
    122
    Re: Draining Pool
    You can gravity siphon most of an above ground pool. The more hoses in it, the faster it will go. Then use a water level when you try to level up the pool.
    29,000 gallon vinyl liner custom designed lagoon style in-ground pool (self-built 2015-2016), Hayward EcoStar VS pump, Hayward HP21404T Heat Pump (140K BTU), Hayward Pro Grid DE DE6020 Filter with Fiber Clear, Hayward Tiger Shark, 2 Hayward Color-Logic LED lights, Stenner 45MPHP10
    370 gallon Jacuzzi J-345 spa with ClearRay UV
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Re: Draining Pool
    Siphon.
    If you have a pool vacuum, that hose will flow a lot more than a garden hose, and the vacuum head will make a nice weight to keep the end down on the bottom. But a garden hose will work.
    Don't try to get the siphon started by sucking on it. Instead, feed it into the water slowly while holding it vertical as it goes underwater so all the air in the hose is pushed out. When the last bit is submerged, cap it with your hand and haul it out and over as fast as possible and get the end below water level in the pool. The siphon will start flowing. Then you can pull the rest of the hose out and drag it where you want, as long as you always keep the outside end lower than the level of the pool.
