Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Above or below seam.....what is the concenus
    Jun 2012
    Central Alabama
    55
    Whats the standard as far as installing a Hayward skimmer on an intex pool goes....above or below the gray seam? Anyone have pics of their above seam setup?
    Intex Ultra 16x48
    Intex 2650 Sand Filter
    Installed June 2, 2012
    Casey's Avatar
    SW PA
    10,438
    Re: Above or below seam.....what is the concenus
    I've seen them done both ways with no ill effects. If you go above the seam, the pool can hold more water.
    Jun 2013
    Buffalo, NY
    80
    I installed mine so the top inside portion of the skimmer is in line with the grey part of the liner. Any higher and you run into the loop for the top rail. I would think this is as high as you can go.
    Intex 16 * 48 Ultra
    2650 Intex Sand Filter
    Hayward Thruwall Skimmer
    Hardplumbed in 2014
    TF100 Test Kit
    May 2016
    Fullerton, CA
    23
    Hey Synergy
    Do you have any pics of your setup and or hard plumbin . I'm am getting ready to install my first AGP and so far have the same equipment as you except I am also doing a SWG. Thanks
    Jun 2013
    Buffalo, NY
    80
    Quote Originally Posted by CASPER570 View Post
    Hey Synergy
    I will have to take new ones tonight. I recently deleted them off of my work computer. I will post up tonight or tomorrow.
    Intex 16 * 48 Ultra
    Hardplumbed in 2014
    TF100 Test Kit
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    About to above...
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Jun 2015
    Stockholm, Sweden
    250
    Definitely above! Mine is even higher than that, works perfectly. Patched for added strenght, just in case.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Quote Originally Posted by Mickelin View Post
    Congratulations, the trend last year was to not go to the seams, but I took the risk, bc I hated to loose water level, now if I have to do it again I will do it like you... 😊
    Jonas Åhgren's Avatar
    Apr 2016
    Stockholm
    144
    Would it be possible to mount the skimmer in the corner, then it could go higher up then the liner? Would only work on the square one of course.
    Jonas Åhgren Lives in Stockholm (Sweden)
    Intex saltwater 24ft X 12ft X 52in Ultra Frame Pool mounted in a wooden frame and deck
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Humm... Interesting idea but I think this will not work... Still I wish someone will come with a solution to this... 😊
    May 2015
    Wichita KS
    29
    I installed mine below the seam, now seeing it can be done above the seam I wish I had done it that way.
    Coleman 18'x48' AGP
    Intex Krystal Clear Sand Filter Pump 2800GPH
    Intex SWG
    **Under Construction** :)
    Jun 2015
    Stockholm, Sweden
    250
    Corner won't work, it is not fixed. But why would you want to higher than I have done? I have no water loss at all. Higher than that and the skimmer will not work properly. The water level should be 1/2-2/3 up the skimmer.
    Apr 2016
    Stockholm
    144
    Ok. But that's great news. No waterlevel needs to be lost 😊
    rdy2fly, can't you patch like Mickelin and after move the skimmer up an inch?
    Has anyone moved the skimmer someplace other than the stock side? Has anyone put it opposite the the return from the filter so that you are pushing water to the skimmer? I would think with hard piping this wouldn't be too big of a deal.
    Jun 2015
    Stockholm, Sweden
    250
    I don't think that would be good for circulation. You want the water to move in a circular fashion around the pool. Also, a lot of piping...
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    The best place to install the skimmer is DOWNWINDS... 😊
    Starting day 5/25/2015 INTEX AGP 24'x12'x54" 8400 gal, with salt and borax, INTEX 16"sand filter, WM Hayward Skimmer, Intex SWG CG-28669, 1 1/2" hard plumbed PVC, Lil' Shark Vacuum With Leaf Canister, TF100 test kit, speed stir, K-1766 Taylor salt test
    May 2016
    Fullerton, CA
    23
    Thank you. I got the pool set up yeaterday... half filled and plan to install the sand filter, swg and skimmer today
    Jun 2012
    Central Alabama
    55
    I decided to go above/even with seam
    The top of my skimmer opening is even with the gray on the liner. Now just have to wait for it to fill up!
    Wow.....that's upside down ��
    Intex Ultra 16x48
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
  20. Back To Top    #20
    Jun 2013
    Buffalo, NY
    80
    RollTide, that is exactly how I did mine. No issues at all. Nice work.
    Intex 16 * 48 Ultra
    Hardplumbed in 2014
    TF100 Test Kit
