Thread: What size concrete base do I need for an Intex Ultra Frame 18' x 9'?
    May 2016
    New Milton, Hampshire, UK
    28
    Does anyone know what size the base should be to take into consideration the frame legs? Also, what depth do you think it would need to be?
    Thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,048
    Re: What size concrete base do I need for an Intex Ultra Frame 18' x 9'?
    Welcome!
    Most people just use pavers set flush with the ground.
    Here's a post that shows the outside dimensions Through Wall Skimmer on Rectangular Intex Ultra Frame UPDATE
    Have you seen Useful links for fellow Intex Pool Owners ?
    This is a great thread showing the ultimate setup of your exact pool. SCroll through and check out the pictures. Newbie - need some help
    May 2016
    28
    Thanks for that. The pool is going on a gravelled area so it has to be a concrete base.
