Thread: Shocking
    May 2015
    Walden, NY
    10
    Shocking
    Could I placed the solar cover on the pool right after shocking it? Thanks!
    18'X33'X52" Aqua Leader. Hayward Perflex EC50 Filter System With 1.5 HP Pump.
    Jun 2014
    15,212
    Re: Shocking
    When we "SLAM" our TFP pools to remove algae (link below), it's best to leave the cover off so the sun can oxidize the combined chlorines more efficiently.
    JoyfulNoise's Avatar
    May 2015
    13,245
    Re: Shocking
    TFP does not teach "shocking" as a routine process except in the context of a SLAM to clear up an algae problem. Once a pool is cleaned and cleared by our methods, routine "shocking" is never needed.
    So my question to you is this - why are you shocking your pool? If you are opening your pool, then you should follow the procedures we have outlined in Pool School for opening a winterized pool and/or SLAM'ing a pool. All of this would normally done with any covers removed.
    Once a pool is clean and clear, the cover can be left on or off as needed with no concern for exposure to chlorine.
    Matt
