Results 1 to 9 of 9
Thread: mini pebble costs
    May 2016
    riverside
    2
    mini pebble costs
    we were told it would cost $2500 additional to upgrade to mini pebble does that sound about right?
    pool is 12450 gallons/hot tub 860 gal in ground. Hayward pro grid filter w/tropic isle gas heater
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Re: mini pebble costs
    If you've settled on the company to do the work, that figure is very much in the ballpark for the cost of an upgrade from plaster to a "standard grade" mini pebble. However, the pool remodel market in So Cal is very robust, such that bid shopping can get you a surprisingly wide range of pricing. Here in San Diego, I secured a bid for mini pebble that matched bids for a plaster finish - and could not be happier with the results (moreover, his lower bid included a complete "chip out" of the old plaster vs. roughing up of the existing plaster and then applying a bond coat as prep for the finial finish).
    Also know that mini pebble itself has a wide range of pricing, depending on the mini pebble line you go with (and varies even within the same mini pebble manufacturer).
    The key is to get as many bids as possible from PBs that have favorable review posts on Yelp.
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
    May 2015
    Land O Lakes, FL
    527
    That sounds about right from upgrading from a standard plaster but there are multiple companies and multiple types of pebble within the same Pebble company so there can be even more variation
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Mar 2016
    McKinney, TX
    156
    That sounds right--did they tell you what "Level" of Pebble at that price? With my pb there was $1400 different between the two colors of Pebblesheen that I liked. Prism Blue (Level 3) was a $1400 upgrade over Blue Surf (Level 1) on 550 square foot pool.
    17K gallon, 18x40, 107 perimeter, 550 sq ft gunite inground pool with raised spa. 3.5 ft. - 5.0 ft. - 4.0 ft depth. Pentair equipment. DE filter. English Walnut travertine paver decking, lueders limestone coping. Wet Edge Primera Stone Sapphire Treasure plaster.
    May 2016
    Los Angeles
    1
    Our base bid was 5700 for plaster. We asked for a cost to upgrade to mini pebble and they came back with an additional 5800.
    We had to rethink that number. Seemed super high to me.
    Apr 2018
    Vista
    1
    Quote Originally Posted by Jaimslaw View Post
    Could you share the name of you refinisher? I am in Vista and looking at exactly the same
    Jul 2017
    East San Diego County, Ca
    26
    I would like to know as well, please!!
    Just broke ground on OB 35x17 geometrical pool with attached 7x7 raised spa...let the fun begin!
    Jul 2011
    Scottsdale, AZ
    54
    Quote Originally Posted by Skav View Post
    That sounds outrageous. Seems like the PB was inflating the cost because they either don't like doing pebble or don't want your job.
    15,000gal IG Stonescapes Mini Pebble Aqua Blue | Pentair CCP520 Cartridge Filter |
    Pentair Intelliflo VS | Robot TBD |
    12,000gal IG Plaster Pool <> Sta-Rite System 3 S7D75 D.E. FILTER <>
    Hayward Ecostar VS <> A&A In-floor Sytem <> IG Spa <>
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Quote Originally Posted by Charred1 View Post
    Gammon Pools (Donnie Gammon).
