Thread: Beaded Liner Question
    Can I replace my overlap pool liner with a beaded liner. I understand most newer pools all have beaded now. Is it easier, last longer?
    Thanks!
    Re: Beaded Liner Question
    From what I have read in the past, overlap is the preferred way to go.. As for retrofitting a beaded liner inot your pool, I'm guessing it's more effort than it's worth.
    Mar 2009
    NJ
    215
    Quote Originally Posted by badutahboy
    Hmmm, maybe I shouldn't have paid extra for that beaded liner I got. Beaded liner AND the extra strips to hang it! Ouch! I too, thought it was easier to replace when the time came to do it. Who knows when that will be, but I wanted to be "prepared". Oh well.
    I'm also installing a deck on top of two sections of pool ledging. I was hoping not to have to take the deck and ledges off to replace the liner when it came time.
    Just a side note to any newbies out there (I am one of them) thinking of getting a beaded liner. I bought a "beaded liner" because I was told I could replace the liner this way. Then I realized a couple weeks later, by accident, that I also needed a snap bead or bead track, or something else installed in order to do what I originally bought it for. So, yes, I did buy the top track for it as well. Had I not done that, I could have still installed the "beaded liner" but without the benefit of taking it off with the pool top ledges still on.
    18' x 54" Round AG 7500 gallon w/small prefab 2-piece fandeck
    Waterways 200sf Cartridge Filter, 1.5 hp 2-speed pump. 2" pvc piping
    Pool Pilot Total Control swg w/acid tank feeder
    Pool Rover Jr., BBB, TF 100 test kit
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    FYI, overlap liners are cheaper and easier to install/replace. The pattern selections are, however, more limited with an overlap. A "beaded" or uni-bead, or J-bead, or duo-bead is used with patterned liners because the "tile" pattern at the top will always be in line with the top railing. In an overlap, that "tile line" is very hard to keep straight.
    If you have a 48" wall, your choices for beaded are becoming very limited, as the 52-54" wall pools are much more popular.
    Yes, you can add a bead reciever to your overlap-style pool, in most cases, and it's not horribly costly. See how HERE.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    Missouri
    42
    Hi, installing a deck over the top rails of your pool is a very good reason to make the switch to a beaded liner. It's one of the very few reasons that make sense to me, but it is a very good one.
    Best of luck and don't forget the photos.
    Dennis
    Pro pool installer for over 35 years
    Shadebuilder.com
