Thread: How long will it take SWG to get the chlorine up
    Jul 2014
    Tempe, arizona
    19
    Pool was looking mucky.
    SWG clean light going off.
    Cleaned SWG.
    FC not even reading...
    Running boost to get levels up to normal.
    Is there a faster easier way?
    In ground
    Intelliflo VS
    Side suction Robot
    Aug 2010
    Dallas, TX
    4,052
    Re: How long will it take SWG to get the chlorine up
    If your water is not clear, you need to stop and SLAM. This is not a job for your SWG.
    Pool School - SLAM - Shock Level And Maintain
    Jul 2014
    Tempe, arizona
    19
    What do I do to slam.
    So I should turn off the SWG and slam?
    Explain what I need to do
    In ground
    Intelliflo VS
    Side suction Robot
    Aug 2010
    Dallas, TX
    4,052
    Click the link I posted, it has all the directions.
    Jul 2015
    Western NC
    115
    Quote Originally Posted by swimmerdude View Post
    Cleaned SWG.
    Using regular bleach is a faster and easier way to increase the chlorine level.
    Did you just open the pool or has it been okay for some time ? How are you testing the water ? Post a complete set of values.
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yes turn off the SWG.
    Read the linked article/instructions - and if possible, please post a full set of test results - even if you have to get it tested at the pool store....
