Thread: Finding replacement caps
    I have a older pool and can't find the caps to cover the vinly liner that goes around the cement blocks. Does anybody have any ideas?
    15'x30' AG/12,800 gallons
    Waterway 2.0 HP pump with cartridge filter
    Jandy Lite2 125,000 BTU Natural Gas Heater
    Mirage Robotic Pool Cleaner.
    Feb 2008
    Denton, TX
    5,061
    Re: Finding replacement caps
    Welcome to TFP!
    Might you be able to post a picture of one so that we can see what you are looking for?
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Do you mean the coping? Plastic or metal?
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    If those are aluminum...Your best bet would be to call your local siding and aluminum gutter contractors...the may be able to fab custom aluminum pieces...or if it happens to be galvanized sheetmetal (doubt it) your local Air conditioning contractor could fab galv sheetmetal. Hope this helps
    Jun 2007
    Poplar Bluff, MO
    11
    I believe I have the same type pool where the liner wraps over a 2 x 6 or 2 x 8 and the cap covers where you staple the liner down. I am replacing the liner this year and plan on putting brick coping on top of the concrete blocks and switching over to a beaded liner. This may be an option for you if your ready to change liners. The brick will make a nice seat around the pool.
