Thread: Water tile grout
    Water tile grout
    If your water tile is blue, do you go with blue grout to match tile so the grout lines stick out? Do you have to have grout lines or can they install without? Advice?
    Pool Size=23,000 gallons
    DE Filter = DNS 48 sqft
    In ground pool
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,549
    Re: Water tile grout
    There are many colors of grout AND you can go almost groutless as well. Pick what works best for you and the look you want. Lots of people use a gray grout to help it blend.
    Kim
    Feb 2016
    Houston, TX
    77
    I considered blue grout for our blue/teal tile, but I went with a light gray. I think either would have looked great, but blue grout scared me a bit.
    Water in, we're swimming! IG 18x29 gunite, 3.5-6.5 depth, 14,000 gallons approx, 1 skimmer, Hayward 4030 cartridge filter, Hayward Tristar VSP, 20 ft. raised bond beam with sprayers, 40 sq ft sunshelf with 2 bubblers, 7 ft round attached spa, Hayward 250k heater, quartz plaster, travertine coping, approx 800 sq feet acrylic deck
