Thread: Water temp of test sample
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    Soon I'll be opening my pool. If I remember correctly in previous years water temp in opening was 60 or lower. Should I bring water temp to room temp before testing?
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    Jan 2009
    Cupertino, CA
    Re: Water temp of test sample
    pH should be tested without warming up.
    In my experience the CH test is kind of sluggish with colder water.
    Some people also say for the CYA test you should warm it up to 70F, but others say they don't find any difference.
    BBB "Intermediate Swimmer"
    FC, CC, and PH should be tested right away. PH shifts with temperature, and chlorine can actually evaporate right out of the sample container if you leave it sitting, in addition to being destroyed by sunlight. TA and CH don't really matter, though you may need to swirl the CH test longer at lower temperatures. CYA works more reliably at room temperature, though if you give it enough time to react it will work with cold water.
