Thread: Pool Reopening Stain
    We have a Tahoe Blue pebble tec finish. Water lowered 1 ft and we have a stain at that level all the way around the pool. What is easiest way to make it go away. Scrubbing with a brush does not seem to do much
    Thanks
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Pool Reopening Stain
    Gotta figure out what "kind" of stain first. If you have one, try rubbing one of those chlorine pucks on it and see what happens. If nothing, try rubbing some cheapo crushed up Vitamin C tabs on an area and report back. Welcome to the forum.
    The stain is result of the leaves that end up getting under the pool cover - heavily wooded area.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    The two tests Woody talked about above are still needed before we can really tell what the best next thing should be.
    Kim
    Apr 2010
    East Texas
    9,643
    Leaves equal organic stains so a puck or two should let you know for sure.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    If a puck lightens the stain then holding your chlorine elevated, like halfway between target and shock level for your CYA, Chlorine CYA Chart and brushing daily or more often will clear up the stain in a couple of weeks or three.
