Results 1 to 9 of 9
Thread: Solar Cover
    May 2014
    Clinton,Iowa
    42
    Solar Cover
    Well I am in need of a new solar cover this year. Who would have thought so many choices. I see there is black and silver and blue? Is there a difference? Different mils?
    28' Above Ground Pool, 20,000 Gallons
    Sand Filter"
    Model #AC16985
    Pool built in July 2012
    Clinton, Iowa
    38,274
    Re: Solar Cover
    Generally, they all seem to last only a couple seasons regardless of thickness or color. Buy the cheapest you can find
    You are better off with the blue or clear as more of the sun will penetrate it.
    May 2014
    Clinton,Iowa
    42
    Re: Solar Cover
    Will the black ones heat it better? What about the mil? It seems taking it on and off tears real easy are the thicker ones tougher?
    Sand Filter"
    Model #AC16985
    Clinton, Iowa
    38,274
    Re: Solar Cover
    I am not sure how to add anything more to my previous post.
    No, the black will not heat better.
    Thicker is heavier and more difficult to work with and more expensive, yet do not seem to last much if any longer.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    Re: Solar Cover
    8 mil is a good one to go with, not too heavy so one person can put it on or remove it.
    I just bought a new one myself...if you look on ebay they seem to cost a lot less even though
    the same company selling them on their own website charge much more.
    I got a 16x32 oval blue 8-mil for $ 67 with free 2-day shipping...wow! Last one I bought like that was over 100.
    Dolphin E10 Cleaning Robot.
    Jul 2014
    Oakbank, Canada
    389
    Re: Solar Cover
    Clear is the best, allows the sun to penetrate and heat the water. I have tried the blue and the clear, clear worked best. Any cover only last 3 years max.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    Re: Solar Cover
    I have had blue and clear, the clear heated better than the blue and both were the same mil
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
    38,274
    Re: Solar Cover
    I hate the name "solar cover"
    Let's all remember that the cover is not "heating" the water. It is retaining the heat in the water that would be lost to evaporation. If you have little wind and your humidity is not very low, you will actually add more heat to the water with NO cover on the pool while the sun is shining on the water. (This is why the clear cover seems to heat the most) After which you need to cover the water to reduce losses at night.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    Re: Solar Cover
    clear though slightly better for heating, the trade off is you lose slightly more chlorine to the sun.
    For that I stick with blue.
