Thread: salt level and jandy aquapure
    Sep 2015
    Austin
    137
    Just a quickie guys. The manual says 4000ppm salt. The SWG chemical balance in the sticky says 3200ppm. Should I go with the levels recommended in the manual?
    26,390 gallons IG, Centex plaster, Hayward DE 4820 filter, Century Centurion B2859 pool pump motor.
    Booster pump for polaris 280
    Spa
    Built 1997
    Jun 2011
    Long Beach, CA
    2,784
    Re: salt level and jandy aquapure
    Double check the manual as my old Jandy Aquapure's max limit was 4000. The manual should state a range of salinity and I usually shoot for the middle which is around 3000 for most SWG's here in the USA.
    Sep 2015
    Austin
    137
    The manual (aquapure ei) says this on page 19.
    4.7.3• 4,000 ppm of salt is recommended for optimum water conditions.• Low salt concentration below 3,000 ppm will cause premature cell failure.• High salt concentration above 6,000 ppm may cause corrosion damage to pool fixtures
    Based on this, it's ok to shoot for 4000ppm?
    Spa
    Built 1997
    Jun 2011
    Long Beach, CA
    2,784
    Yes, 4000 is the level you should target.
