Thread: Opening above ground. What order?
    Jul 2014
    Georgia
    13
    Opened the pool this weekend and here are the numbers
    Fc 1.5
    Cc 0
    Ch 25
    Ta 44
    Cya 35
    Ph 7.4
    Salt 1590.
    I was think salt, cya, ta, ch, and then fc. What are y'all thoughts.
    16,000 gals. 27 Round AG. Intex SWG. 1.5 hp Hayward Power Flo Lx. Jacuzzi 190L sand filter. TF-100. Full sun.
    Jun 2014
    15,103
    Re: Opening above ground. What order?
    The fact you still have CYA remaining is great. Bump that FC up to at least 5 for now and consider doing an OCLT to be sure nothing is growing. If you fail the OCLT, do a SLAM right away before increasing your CYA to the 70-80 range. Here's the TFP page for Pool School - Opening Your Winterized Above Ground Pool.
    Jul 2014
    Georgia
    13
    Do I need to do a OCLT water is just about crystal clear. I can see all the wrinkles in the liner very well.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    I'd get things balanced and squared away as a bleach pool, then add the salt and fire up the SWG. To that end, add bleach, mess with the CYA granules and the sock, then dump in the baking soda. Wait a few days until the CYA is all dissolved and fine tune, then add the salt.
    With your vinyl pool, you don't really need CH. You might get some foaming where the return stream breaks the surface, so if it bugs you, raise CH. If it doesn't, save your money.
    Jun 2014
    15,103
    Your call BigRed. If you find after opening and adjusting that FC holds well after increasing, cc continues to be next to nothing, and water remains clear, press-on. Later, you can always run an OCLT if in doubt.
    Jul 2014
    Georgia
    13
    Thanks will start working on it Wednesday and update. This is my 2nd season with with the tfp method and 1st opening.
