This is not a problem, I am just curious: what is the chemical cause of the "latte" foam on my pool surface. Photos attached.
I just removed the cover and all plugs, raked out all the leaves (not a lot this year!!!), ran my pool robot vac to get the stuff the leaf rake can't......and filled the robot's filters each time. Cleaned them, and did it 3x. Now the pool is very clean...water is a little blueish-green, and certainly cannot see the deep-end drains. Not a bad start I think......We had 2 inches of rain, I backwashed to get the level down and ran the filter 5 hours after which I noticed the "latte" foam. Hit it up with 2 gallons of 10% liquid CL before bedtime, and measured this morning. FC= 4.5, CC=0.5, pH= 7.2, CYA around 50 (?), CH=325 and TA around 100. Not terrible numbers for right at start-up. Water Temp: 51.4F. As to the CC...I would have expected higher CC this morning (lower FC) ....so that's odd. And I am really just curious about the "latte foam"...what causes it.
I don't have enough CL to SLAM right now, ordered a 25-pound Cal-Hypo 73% delivery and it'll be here tomorrow. I have 4 gallons of 10% liquid CL2 also. I have no doubt SLAM will make everything perfect, as six years in a row all I do is SLAM at opening, run my SWG and Pool Vac Robot...and yep, trouble-free pool
