Thread: Intex Thread?
    Jan 2016
    Milton, Ontario
    15
    Intex Thread?
    Do you know if or when will Intex users get their own section vs having to share with the other above ground users?
    My pool: Intex 16x42 Easy Set (3800 gallons), Intex Krystal Clear 2800 GPH Sand Filter Pump, Intex Krystal Clear SWG cg-56601
    Casey's Avatar
    SW PA
    10,423
    Re: Intex Thread?
    This is the above ground pool section and Intex is an above ground pool. This is your section.
    Jan 2016
    Milton, Ontario
    15
    Re: Intex Thread?
    I've changed it to above. I meant it's own section
    38,246
    Re: Intex Thread?
    We have talked about it before and fail to see the benefit.
    Casey's Avatar
    SW PA
    10,423
    Re: Intex Thread?
    This is for all above ground swimming pools. They are basically the same except for metal verses soft side. They both stand above ground. You can use the search feature to pull up hundreds of intex threads posted over the years.
