Thread: Changing rollers on Tiger Shark/Aquavac Robot
    Jun 2008
    France
    18
    I need to change to sponge rollers from PVC plastic toggles on a Tiger Shark Drive/Hayward Aquavac Drive. If anyone has done this - can you please tell me how? Thanks!
    Inground Gunnite pool 30'x15' - 10mx5m
    22,500 US Gallons / 85 Cubic M.
    Hayward 3/4 hp Triton Sand Filter 220lbs - 100kg
    Auto pH ColorQ Test Kit
    Mar 2008
    Los Angeles, Ca
    222
    Re: Changing rollers on Tiger Shark/Aquavac Robot
    So, you are either changing from sponge to plastic, or vice versa?
    On an aquabot, on each roller, there are a couple of plastic tabs, that have arrows on the ends, which insert into a slot.
    You just have to unlatch them, and you can take off the sponge/plastic. Do the reverse to install.
    It's been a while since I did this, but it was pretty easy, takes a few minutes, and no tools required.
    Randy
    25,000 gal fiberglass pool, Raypak 200k BTU H200FDN gas heater, Pentair CCP520 520 sq ft Cart filter, Max-Flo VS2303VSP pump. iWave wireless remote,
    seperate spa, with own pump, cartridge filter, Hayward H200FDN heater
    Jun 2008
    France
    18
    Thanks Randy for your quick response - changing from plastic to Sponge. But I think Aquabot is different to Tiger Shark (also Hayward 'Aquavac' over here in France) as I don't have those arrows and I think I need to remove the cover assembly to replace the complete roller - ouch!
    Mar 2008
    Los Angeles, Ca
    222
    I looked on the internet, and it is different.
    I found this diagram
    http://www.aquavacsystems.com/TigerShar ... _18-1.html
    It looks like there are a bunch of little interlocking tabs that hold it together.
    Based on that, you still don't need to disassembly it.
    I would look for a seam in roller, as that is probably where it comes apart.
    Is the sponge roller a rectangle, that would wrap around the inner roller, and then you would have to attach the ends? That's what I had to do.
    Randy
    Jun 2008
    France
    18
    Thanks Randy for that research - problem solved I think!
