Results 1 to 7 of 7
Thread: How soon to start watering shotcrete?
    May 2015
    Fullerton, CA
    636
    They finished at 5pm, currently 46 degrees in so ca. Wet it down tonight or first thing in the morning. I have been reading and recs are over the place. Thx!
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    30,426
    Re: How soon to start watering shotcrete?
    Do it sooner rather than later. Absolutely no harm unless you turn the nozzle to "Blast"
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Keep it wet, especially in the afternoon sun. You can't put too much water on it. Lots of folks put a sprinkler in the pool with a hose timer.
    Jul 2015
    Central Valley CA
    1,109
    Don't worry about water pooling in the deep end whatever does not soak through will get pumped out before plaster. If it is going to be more than a couple of weeks before they plaster you can stop watering after what ever time they told you for cure usually 14 days, but if you do that be sure to wet very well again a couple of times the day before plaster or you can just keep watering it right up to plaster no matter how long the it takes.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    May 2015
    Fullerton, CA
    636
    Thanks, I am working from home today, will get it wet every couple hours. I did mist it last night about 10pm after reading on the ACI site about wetting it down as soon as you can walk on it. Said the 1st 36 hours is the most critical.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,752
    Once you start to get some pooling in the deep area, you can just scoop some water up with a 5 gallon bucket and spread it around with that. No need to waste a bunch of water
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    May 2015
    Fullerton, CA
    636
    Quote Originally Posted by bdavis466 View Post
    Great point! Thank Brian!!
