Results 1 to 9 of 9
Thread: I must be color blind
    langerking's Avatar
    Jul 2013
    Clermont, Florida (that's near Disney World)
    104
    Can't tell for sure if this is 7.5 or 7.7. In the picture it looks like 7.7 to me, in reality it is much harder to determine because it is much more red than pink.
    1) 21,000 gallons
    2) DE
    3) IG (in ground)
    4) Vinyl
    5) Hayward 1.5 hp DE 3600 72 GPM
    Taylor K-2006
    STA-RITE Great White GW9500
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: I must be color blind
    Question: What is your FC level?
    .....and camera pictures of that are awful hard to judge by. Is that looking against a white background?
    Oct 2015
    Katy/Texas
    411
    Drives me nuts too. To bad there is not a better test that does not relie on your interior decorating skills.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    langerking's Avatar
    Jul 2013
    104
    Up against a white background..is that the part I am missing?
    1) 21,000 gallons
    2) DE
    3) IG (in ground)
    4) Vinyl
    Taylor K-2006
    Apr 2010
    East Texas
    9,569
    Or some light sky. I have a white fence sign I compare against.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    is the test tube not full ? It doesnt look like it.
    Divin Dave,
    Apr 2010
    East Texas
    9,569
    Looks a couple windows short for sure...
    langerking's Avatar
    Jul 2013
    104
    Quote Originally Posted by woodyp View Post
    Sent from my XT1030 using Tapatalk
    Goodness gracious - I have been doing this test wrong for months! I had run out o R-0004 solution and switched to my K-1000 kit using the R-0014 and the much smaller tube. Did this for months before buying more test solution. Got confused I guess since all the other tests use 25ml and not 44ml.
    Just retested and found my pH is actually 8.0!! Darn, need to buy more acid now.
    That's why it is good to post your test though - others will see what you don't see! Thank-you TFP!!
    1) 21,000 gallons
    2) DE
    3) IG (in ground)
    4) Vinyl
    Taylor K-2006
    Aug 2014
    Shallotte, NC
    693
    Since you have the K-2006, you have the R-0005 and R-0006 reagents. I find them very helpful to assess colors in the pH test.
