Thread: Jandy Aqualink RS4 - can i control swg from wired remote?
    Jan 2015
    TX
    49
    can i review or configure the SWG from the aqualink RS4 allbuton remote?
    TX/Dallas | 18K ? gal. | Plaster | Jandy valves, Jandy panel, Aqualink RS4
    Pentair Challenger Fixed 2hp | SWG AquaPure PLC1400*repl 2015 | Pentair Clean & Clear 420
    ThePoolCleaner 2wheels
    Jan 2015
    TX
    49
    Re: Jandy Aqualink RS4 - can i control swg from wired remote?
    after i opened and RTFM the answer to my question is yes, however it needs to be wired and the a-ho-ncho who installed it didnt wire the Aquapure to the Aqualink
    ... if i use a '4 conductor outdoor rated' wire... do i have to do any configuration after that?
    Jan 2015
    TX
    49
    i wired the aqualink center to the aquapure, nothing happened ... no message or info on the Remote screen, no message on the Aquapure when changing %
    aquapure seems correct version 120xxx which is higher than 112xxx
    looking in the manuals there's no indication that % can be changed from the remote itself, only programming boost ... and no info that % would be displayed on the Remote screen -- both would have been what i had hoped
    any help appreciated...
    Jul 2015
    239
    What revision is your CPU? I have the OneTouch and the percentage showed with Revision K.
    16,500 gallon IG Pool & Spa: Intelliflo VS pump, Pentair Triton II TR-100 sand filter, Teledyne Laars Lite2 propane heater
    Laminar Jets (2): Hayward Maxflow SP1600 1/2HP, Hayward Star Clear C500 cartridge filter
    Jandy iAqualink RS-8 Rev T, Hayward AquaRite AQR15, Dolphin Supreme M5, Taylor K-2006, Taylor K-1766
