Thread: Siphon Pump
    Apr 2015
    New Bedford, MA
    65
    Siphon Pump
    Bought an air pillow and its deflated 2nd year in a row. whats a good Siphon pump that isnt to expensive to help keep the water off the cover?
    summer scape metal frame AG pool 14x42, 3750 gallons
    INTEX Krystal Clear 2800 GPH sand filter pump
    TF-100 Test Kit Pool Calculator , cya-chart
    Pool school,recommended-levels
    May 2012
    Montville NJ
    545
    Re: Siphon Pump
    Quote Originally Posted by angelover02740 View Post
    You have one, your vac hose.
    Zip tie a weight to the end and throw it on the cover. Take the other end and hold it up above the level of the pool and fill it with water (your DE scoop works well for this). When the hose it full, drop the end you are holding up on the ground. A syphon will start, it will run for as long as the weighted end remains under the water on the cover.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Jul 2014
    Oakbank, Canada
    389
    Re: Siphon Pump
    Yup, and its energy free to use. Costs nothing to operate, works in power outages, no fuel required.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
