Thread: Closing question about filter
    Should I remove the filter cartridges before or after blowing out the lines. Is it okay to have the air blow thru them or is it better to remove them first.
    30,415
    Re: Closing question about filter
    Where do you live? It matters.
    I live in Southern New Jersey. I do store the catridges inside over the winter but was wondering about when I should remove them. Before or after blowing out the lines.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    I would remove them first, and then push air through the system. The cartridges trap dirt, debris, etc., while water is travelling through the cartridges. If you leave them in the filter and blow air through them, you may loosen the trapped contaminants and allowing dirt to enter back into the pool through the skimmers, returns, main drain. This also ensures that you remove the water in the filter housing, therefore eliminating opening the cover up to a foul odor and possibly mold/mildew in the spring.
    Please add your signature:
    Pool School - Read This BEFORE You Post
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    I pulled out my filter (prior to blowing the lines), sprayed it down with the hose, and let it dry outside,, then stuck it in the garage.
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
