Results 1 to 7 of 7
Thread: What happens if....
    Oct 2015
    San Diego, Ca.
    640
    What happens if....
    What happens chemically, if I premix a few jugs of 3/4 Chlorine and 1/4 Muriatic Acid so my "helper" can dump it in as needed? The no-brainer angle........
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: What happens if....
    Since we aren't even supposed to store them near each other I think it's a BAD thing. Also, they make a big deal about never mixing them in the pool. Should allow at least 30 mins between and only if the pump is running.
    I'm sure someone with more actual experience or chemical reasoning will be along soon. I just wanted to make sure you had some type of answer as soon as possible.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    i think it creates chlorine gas
    the stuff they use in wars and will probably kill you
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    domct203's Avatar
    Jun 2015
    CT
    3,581
    Quote Originally Posted by aussieta View Post
    +100000
    DO NOT EVER MIX CHLORINE & MURIATIC ACID. THIS WILL CREATE A DEADLY CHLORINE GAS THAT CAN KILL YOU OR OTHERS AROUND YOU.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Donldson's Avatar
    NW Ohio
    2,892
    From the CDC: http://www.cdc.gov/mmwr/preview/mmwrhtml/00015111.htm
    On December 7, 1988, a patient assisting in janitorial duties mixed bleach with phosphoric acid cleaner. Immediately a noxious gas with a strong odor was detected and prompted the evacuation of two wards for 1-1/2 hours. Fire department personnel using self-contained breathing equipment disposed of the chemicals and ventilated the area.
    The patient experienced vomiting, cough, and inspiratory discomfort; elevated blood pressure and fever were noted when the patient was treated in the emergency room. Five employees who helped evacuate the ward complained of symptoms including eye irritation and shortness of breath.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Oct 2015
    San Diego, Ca.
    640
    Quote Originally Posted by domct203 View Post
    +100000
    Dom
    I"ll take that as a NO!
    Thanks everyone for saving my pathetic life......
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    ^ or the life of your helper, as the case may be
    This is why there's no such thing as a stupid question!
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
