Correct. 2 things consume FC. UV and organics. You lost no FC without the UV, so there is nothing growing in the pool.my understanding is that the results of the test indicate that the chlorine loss is happening during the day? I assume that is due to the low CYA
Losing 1.5 FC per day is fair for TX for April. Nothing is wrong there. You want to raise the CYA instead for your SWG.
You proved it was safe to do so with the OCLT. Slam suuuuuuuuucks at 28 FC / 70 CYA, when it's only 12 FC for 30 CYA. You had the ability to SLAM at 30 right now and proved you didn't need to.
Proceed with targeting 70 CYA. Add 75% of what you need and creep the rest of the way.
Also, you need to keep your FC free and clear from minimum.
Or once the SWG is going
