Thread: Folders randomly only show 8 topics.
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Has anyone else noticed this? It happens to me seemingly randomly, but on a consistent basis.
    Screenshot: http://i.imgur.com/mMt5h4G.png
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,092
    Re: Folders randomly only show 8 topics.
    Try changing your "Default Thread Age Cut Off" setting,
    Settings > General Settings (box on the left hand side) > Default Thread Age Cut Off > Show all threads
    That should display more threads when searching inside of individual forums.
    Jul 2015
    Kentucky
    1,126
    Hi Ping. I don't know if this will fix what your asking about, but at the bottom of the Forum page where it says show threads from: Change that to Last Month, 45 days, 60 days etc. and it will pull up more. Mine is currently set at 2 weeks and it too shows 8 but if I change it to the Last Month I then get 15 etc. I hope this helps.
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Thanks all, that did it.
    Test Kits:
    My Pool:
