Thread: Hayward Pool Vac hose problem
    I recently purchased a Hayward pool vac. It works great for a while but the hose ends up in the water intake where the filter basket is. This problem limits the range of the vac. Any ideas?
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    Re: Hayward Pool Vac hose problem
    Make sure you don't have too much hose attached. The hose should reach from the vacuum port to furthest part of your pool from that port. Any more than that and you'll have excess coils of hose that can get sucked up.
    Thanks for the quick reply. I will try removing a section to see if this resolves the problem.
