Thread: Pool Tite glue
    Aug 2015
    San Diego, CA
    16
    Pool Tite glue
    Another recommendation was to use Pool Tite glue. Is that stuff any better than a standard PVC glue? Anyway is there a special glue/brand I should use?
    27,000 gal in ground white plaster pool. Sta-Rite System 3 DE filter, Sta-Rite heater and 2 HP pump. Solar heating on roof.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pool Tite glue
    I take it your connecting PVC pipe?
    I used Oatey 30893 PVC Rain-R-Shine Cement, Blue and the purple primer from lowes.. it is a "hot" glue and works great as long as the outside temps are below 90 degrees, you have to be fast when connecting because it sets very fast... it still works great above 90 degrees, you just have to be really fast when connecting
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Pool Tite glue
    Christy's Red Hot Blue Glue is what I use for all my PVC connections.
    However, the key is to use the purple primer to ensure a good, solid, leak-free joint.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Nov 2011
    Moberly,MO
    1,010
    Re: Pool Tite glue
    We have used Oateys clear primer for over 30 years and it hasn't ever failed. Also used Oateys all weather cement there again never an issue.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Re: Pool Tite glue
    Probably more important than which glue is to follow good procedure. Any pvc glue should work well as long as the joints are made correctly.
    Support the site
