Thread: Vacuuming in Waste mode
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    How much water will I lose in the pool, if I vacuum in waste mode, so it wont fill my sand filter up with mud silt. Or will it be ok to vacuum through the filter and backwash real good??
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Vacuuming in Waste mode
    If you're sucking out a good amount of mud and silt, I would do it in waste mode to bypass the filter. Yes, your pool volume will go down, but how much depends on the GPM of your pump and how long you do it.
    Isolated Spa - 345 Gallons
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    It can go down real fast, so just be aware of the water line...maybe even over fill a little to be safe first.
    My last pool I only had about 10 minutes of time before the fill line went down far enough to start sucking air from the skimmer/vac inlet.
    Dolphin E10 Cleaning Robot.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Not good...I am on a well!! Thanks!
    Mark
